1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: stdout being changed in EPICS
To: [email protected]
Date: Thu, 17 Jul 2008 18:25:08 -0400
On 7/17/08 9:31 AM, Mark Rivers wrote:
> I’ve done some more investigation of this.  It appears that stdout is
> being closed and re-opened when the vxWorks startup script completes.
>  Does anyone know if this is true?  If so, I don’t understand why.  I
> can understand why stdin may be reopened, changing from the startup
> script to the console.  But why stdout?  Is there a way to open a file
> descriptor to the console that will not be closed and re-opened when the
> startup script completes?
Hi, Mark.
I looked at src/iocsh/iocsh.cpp in EPICS base 3.14.9 and it seems to be
doing some special things with (FILE *) references to support
redirection.  Maybe this is causing the problem?  The comment in the
file indicates the original author was Marty Kraimer and that it was
modified by Eric Norum a little later.
There are about four places in the file where fclose() is called on a
(FILE *) reference.  You could add a print statement before these to see
if this is indeed where stdout is getting closed.
But I bet Marty or Eric know better.
Lewis
> *From:* Mark Rivers
> *Sent:* Wednesday, July 16, 2008 7:07 PM
> *To:* EPICS tech-talk
> *Subject:* stdout being changed in EPICS
> Folks,
> I have run into a problem with the value of stdout being changed some
> time after iocInit is called.  This is happening at least on vxWorks, I
> have not checked other platforms.
> This is a real problem, because I have a vendor library that assigns a
> file descriptor to the value of stdout before iocInit is run, and then
> does fprintf() to that file descriptor for logging purposes.  This works
> fine until just after iocInit is called, at which point that file
> descriptor is invalid (fprintf returns an error), and the value of
> stdout has changed to a new value.
> One can easily reproduce this problem with the example application that
> EPICS base generates.  I just added this small global function
> show_stdout() to the end of devXxxSoft.c
> corvette> tail devXxxSoft.c
>     /*If return was succesful then set undefined false*/
>     if(!status) pxxx->udf = FALSE;
>     return(0);
> int show_stdout()
>     printf("stdout=%p\n", stdout);
>     return(0);
> Here is what I see at the end of the st.cmd file, to which I added calls
> to show_stdout just before and after iocInit:
> show_stdout
> stdout=0x1d0e290
> value = 0 = 0x0
> iocInit()
> Starting iocInit
> ###  EPICS IOC CORE built on Jun  9 2008
> ###  EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
> iocInit: All initialization complete
> value = 0 = 0x0
> show_stdout
> stdout=0x1d0e290
> value = 0 = 0x0
> ## Start any sequence programs
> seq &sncExample,"user=epics"
> SEQ Version 2.0.11: Mon Jun  9 16:03:45 2008
> Spawning state program "sncExample", thread 0x1c2e7c0: "sncExample"
> value = 29550528 = 0x1c2e7c0
> Done executing startup script
> /home/epics/devel/example/iocBoot/iocexample/st.cmd
> iocexample> show_stdout
> stdout=0x1ffe738
> value = 0 = 0x0
> Note that the value of stdout is 0x1d0e290 before the call to iocInit,
> and just after iocInit returns.  However, the value has changed to
> 0x1ffe738 when I type the show_stdout command manually a few seconds
> after I get the vxWorks prompt.  This happens whether or not the SNL
> program is run (comment out the seq call).
> Does anyone know why the value of stdout is changing?  It is a real
> problem for software that uses the value of stdout through a call to
> iocInit.
> Thanks,
> Mark
Re: stdout being changed in EPICS Eric Norum
RE: stdout being changed in EPICS Mark Rivers
Prev: RE: Building 32-bit EPICS binaries on 64-bit Linux systems Allison, Stephanie
Next: Re: stdout being changed in EPICS Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: stdout being changed in EPICS Mark Rivers
