On Jul 17, 2008, at 5:25 PM, J. Lewis Muir wrote:
On 7/17/08 9:31 AM, Mark Rivers wrote:
I’ve done some more investigation of this. It appears that stdout is
being closed and re-opened when the vxWorks startup script completes.
Does anyone know if this is true? If so, I don’t understand why. I
can understand why stdin may be reopened, changing from the startup
script to the console. But why stdout? Is there a way to open a
file
descriptor to the console that will not be closed and re-opened
when the
startup script completes?
Hi, Mark.
I looked at src/iocsh/iocsh.cpp in EPICS base 3.14.9 and it seems to
be
doing some special things with (FILE *) references to support
redirection. Maybe this is causing the problem? The comment in the
file indicates the original author was Marty Kraimer and that it was
modified by Eric Norum a little later.
Not an issue.
Mark isn't using iocsh.
There are about four places in the file where fclose() is called on a
(FILE *) reference. You could add a print statement before these to
see
if this is indeed where stdout is getting closed.
But I bet Marty or Eric know better.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- RE: stdout being changed in EPICS Mark Rivers
- Re: stdout being changed in EPICS J. Lewis Muir
array calc / inverse subarray survey? Rowland, J (James)
<2008>
2025
2026
VXI resource manger converted to R3.14? Nicholas P. DiMonte
<2008>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
