1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building 32-bit EPICS binaries on 64-bit Linux systems
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 18 Jul 2008 09:14:27 -0500
Mark,
For R3.14.9 add the following 2 lines to  CONFIG.Common.linux-x86
ARCH_DEP_CFLAGS += -m32
ARCH_DEP_LDFLAGS += -m32
Also you could add the following 2 lines to  CONFIG.Common.linux-x86_64
ARCH_DEP_CFLAGS += -m64
ARCH_DEP_LDFLAGS += -m64
Janet
Mark Rivers wrote:
Folks,
I want to build EPICS in 32-bit mode on a 64-bit Linux machine.  I had assumed that all I needed to do was to define EPICS_HOST_ARCH to be linux-x86, rather than linux-x86_64.  But when I do this it creates the expected directories and binaries, e.g. bin/linux-x86/caRepeater, etc. but the binaries appear to be 64-bit.  Running “file” on them reports them at ELF 64-bit files.  My IOC is crashing, and I suspect it is because it is built as a 64-bit application.   How do I force it to be built as a 32-bit application?  This is EPICS R3.14.9.
RE: Building 32-bit EPICS binaries on 64-bit Linux systems Mark Rivers
Prev: MAXv problem update EPICS record jerome HOSSELET
Next: RE: array calc / inverse subarray survey? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Building 32-bit EPICS binaries on 64-bit Linux systems Mark Rivers
Next: RE: Building 32-bit EPICS binaries on 64-bit Linux systems Mark Rivers
