1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: array calc / inverse subarray survey?
To: "Rowland, J (James)" <[email protected]>, <[email protected]>
Date: Fri, 18 Jul 2008 11:23:14 -0500
One suggestion for this would be to use an SNL program.  That way the fact that there is only 1 link does not matter.  The SNL code could read the value, modify it, and put it back.  Or it can read the data from an input waveform (every time it changes using monitors, for example) and write the output to annother output waveform.
SNL has the advantage that it uses channel access, so it can run on any machine, including but not limited to the IOC with the waveform records.  For things like FFTs that can be nice because there are often better libraries available on Linux/Windows/Mac then there are on vxWorks, for example.
From: [email protected] [mailto:[email protected]] On Behalf Of Rowland, J (James)
Sent: Friday, July 18, 2008 6:13 AM
To: [email protected]
Subject: array calc / inverse subarray survey?
Hi
I’d like to do some array calculations (FFT, rectangular to polar, filtering etc). I’d like the option to run at high rates (KHz) which would suggest using asyn. Is there any standard for this? Some possibilities are aCalcout, waveProc, genSub. If the waveform record had an input and an output I could easily put the calculations in the asyn layer but I can’t see an obvious way to build a processing chain with only one link. Any suggestions?
Also is there a standard for inverse subarray? I’d like to combine 100s of scalar PVs into one waveform.
Thanks
James
Senior Software Engineer
Diamond Light Source
array calc / inverse subarray survey? Rowland, J (James)
Prev: Re: Building 32-bit EPICS binaries on 64-bit Linux systems Janet Anderson
Next: Re: MAXv problem update EPICS record Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: array calc / inverse subarray survey? Rowland, J (James)
Next: Re: array calc / inverse subarray survey? Luedeke Andreas
