1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Gated ADC
To: "Leicester, PJ (Pete)" <[email protected]>
Cc: [email protected]
Date: Wed, 6 Aug 2008 07:03:03 +0900
Hello,
Maybe this is not the one you need.  But in case ...
<http://www.kagaku.com/hoshin/e-pdf/v005.pdf>
Charge integration ADC
VME, 8channels,
30-nano to 1-micro-second integration gate,
14bit,
1-nano-Coulomb  max.
Conversion time 15micro-second, so 10k sa/s should be possible.
Best regards.
On Tue, Aug 5, 2008 at 5:20 PM, Leicester, PJ (Pete)
<[email protected]> wrote:
> Can anyone recommend a hardware gated ADC? We need one with the following
> features:-
> 1) Data collection controlled by a hardware gate signal such that data is
> collected into a buffer when the gate is enabled and when the gate is
> disabled an interrupt is generated so the data can be transferred into an
> I/O Intr processed waveform (or similar) record.
> 2) Sample rate up to at the least 10KHz but preferably 100KHz, and an
> absolute minimum of 16 bit.
> 3) Epics support for waveform record (or MCA or similar).
> 4) Preferably packaged as an IP module but a VME card would be OK.
> Note that the essential feature is the gating of collection on the hardware
> signal. We do not want to trigger and collect a fixed number of samples
> (most ADC's do this).
> Any suggestions would be gratefully received.
> Pete
Kazuro FURUKAWA <[email protected]>
 Linac&KEKB, High Energy Accelerator Research Organization (KEK), Japan
 Telephone: +81-29-864-5200 x4316, Facsimile: +81-29-864-0321
Gated ADC Leicester, PJ (Pete)
Prev: Re: Bergoz LR-BPM Monitoring system for LINAC Kazuro FURUKAWA
Next: Re: EPICS to Python / EPICS to Tcl Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Gated ADC Leicester, PJ (Pete)
Next: RE: Gated ADC Graham Cross
