1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: RE: Loosing half the monitor callbacks
To: "Dehong Zhang" <[email protected]>
Cc: [email protected]
Date: Sat, 9 Aug 2008 16:10:21 -0500
When you say "raise a monitoring with the last 144 data points" what do you mean?
Are you averaging these points, or are you posting an array, or something else?
Sent: Fri 8/8/2008 5:05 PM
To: Mark Rivers
Subject: Re: RE: Loosing half the monitor callbacks
Hi Mark,
Thank you!  My ioc is indeed changing very fast -- triggered by some hardware at 720 Hz, then
every the 144th time I call the db_post_event method to raise a monitoring with the last 144 data
points.  Somehow i just miss every the other monitoring.  I tried to slow down the clock by 8 times,
it (camonitor) is still doing the same thing.
Best regards,
Dehong
----- Original Message -----
Date: Friday, August 8, 2008 4:32 pm
Subject: RE: Loosing half the monitor callbacks
To: Dehong Zhang <[email protected]>, [email protected]
> What happens when you run the "camonitor" utility from EPICS base at
> the command line on that PV?  Perhaps the PV is really not changing
> like you think it should be.
> Mark
> ________________________________
> From: [email protected] on behalf of Dehong Zhang
> Sent: Fri 8/8/2008 4:18 PM
> To: [email protected]
> Subject: Loosing half the monitor callbacks
> Hi,
> I would like to monitor a PV at 5 Hz.  Somehow I do get 5 callbacks
> every seconds
> but only get the changes every the other time, like getting changes
> 1st, 3rd, 5th ...
> two times, but never get changes 2nd, 4th, ...
> Could you please enlighten me?
> Thanks and best regards,
> Dehong
Re: RE: RE: Loosing half the monitor callbacks Dehong Zhang
RE: Loosing half the monitor callbacks Mark Rivers
Prev: Re: Loosing half the monitor callbacks Tim Mooney
Next: Re: RE: RE: Loosing half the monitor callbacks Dehong Zhang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Loosing half the monitor callbacks Mark Rivers
