1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RE: RE: Loosing half the monitor callbacks
Cc: [email protected]
Date: Sat, 09 Aug 2008 18:22:22 -0500
Hi Mark,
Thank you!
I am posting an array of floats.  I tried to monitor a simpler case, a single float,
still got the same behavior.  Somehow I enter the wrong 'if' block in
db_post_single_event every the other time.
Best regards,
Dehong
----- Original Message -----
Date: Saturday, August 9, 2008 4:11 pm
Subject: RE: RE: Loosing half the monitor callbacks
To: Dehong Zhang <[email protected]>
> When you say "raise a monitoring with the last 144 data points" what
> do you mean?
> Are you averaging these points, or are you posting an array, or
> something else?
> Mark
> ________________________________
> From: Dehong Zhang [mailto:[email protected]]
> Sent: Fri 8/8/2008 5:05 PM
> To: Mark Rivers
> Subject: Re: RE: Loosing half the monitor callbacks
> Hi Mark,
> Thank you!  My ioc is indeed changing very fast -- triggered by some
> hardware at 720 Hz, then
> every the 144th time I call the db_post_event method to raise a
> points.  Somehow i just miss every the other monitoring.  I tried to
> slow down the clock by 8 times,
> it (camonitor) is still doing the same thing.
> Best regards,
> Dehong
> From: Mark Rivers <[email protected]>
> Date: Friday, August 8, 2008 4:32 pm
> Subject: RE: Loosing half the monitor callbacks
> To: Dehong Zhang <[email protected]>, [email protected]
> > What happens when you run the "camonitor" utility from EPICS base at
> > the command line on that PV?  Perhaps the PV is really not changing
> > like you think it should be.
> > Mark
> > From: [email protected] on behalf of Dehong Zhang
> > Sent: Fri 8/8/2008 4:18 PM
> > To: [email protected]
> > Subject: Loosing half the monitor callbacks
> > Hi,
> > I would like to monitor a PV at 5 Hz.  Somehow I do get 5 callbacks
> > every seconds
> > but only get the changes every the other time, like getting changes
> > 1st, 3rd, 5th ...
> > two times, but never get changes 2nd, 4th, ...
> > Could you please enlighten me?
> > Thanks and best regards,
> > Dehong
Loosing half the monitor callbacks Dehong Zhang
RE: Loosing half the monitor callbacks Mark Rivers
RE: RE: Loosing half the monitor callbacks Mark Rivers
Prev: RE: RE: Loosing half the monitor callbacks Mark Rivers
Next: Re: Loosing half the monitor callbacks Dehong Zhang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Loosing half the monitor callbacks Mohan Ramanathan
