As much as I would consider adding scan "60 second", and that seems
human readable enough, I would ponder on SCAN="4 hours": when you get
the sample would depend on iocInit time, not necessarily the intented
purpose?
It sounds like a problem SNL would better address, schedule something to
happen at midnight, 4 am etc.
Allison, Stephanie wrote:
The SCAN field is an enum-type. You can alter epics-base and extend the
range of options, but it will remain enum. Are you refering to another
mechanism? 'seq' records allow specifying arbitrary delay DLY<n> when to
process OUT<n> links, but that's also in seconds.
Even though SCAN is enum, the scan task finds the # of seconds (which it uses to delay between cycles) from the menu ASCII name using strtod (see 17.3.1 of the App Dev Guide). This is unusual. It would be nicer if menuScan.dbd had 3 fields for every option - the enum value (index number), the user-friendly name, and the "raw" name which is used by the scan task. But this is a change to epics base and probably not worth the effort.
Stephanie Allison
Matthieu Bec Gemini Observatory
Tel: +56 51 205785 c/o AURA, Casilla 603
Fax: +56 51 205650 La Serena, Chile
- RE: Scan Time Definitions Erik Johansson
- Scan Time Definitions David Dudley
- Re: Scan Time Definitions Matthieu Bec
- RE: Scan Time Definitions Allison, Stephanie
<2008>
2025
2026
<2008>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
