> The SCAN field is an enum-type. You can alter epics-base and extend the
> range of options, but it will remain enum. Are you refering to another
> mechanism? 'seq' records allow specifying arbitrary delay DLY<n> when to
> process OUT<n> links, but that's also in seconds.
Even though SCAN is enum, the scan task finds the # of seconds (which it uses to delay between cycles) from the menu ASCII name using strtod (see 17.3.1 of the App Dev Guide). This is unusual. It would be nicer if menuScan.dbd had 3 fields for every option - the enum value (index number), the user-friendly name, and the "raw" name which is used by the scan task. But this is a change to epics base and probably not worth the effort.
Stephanie Allison
- Re: Scan Time Definitions Matthieu Bec
- Scan Time Definitions David Dudley
RE: Scan Time Definitions Allison, Stephanie
<2008>
2025
2026
<2008>
2025
2026
