we have bought some Lambda Gen 8-180/LAN power supplies, which look from the documentation "practically" the same as the power supplies from Agilent. Nevertheless they use as low level protocol their private raw socket interface, which involves fiddling with the packet headers, etc. How difficult would it be to implement this as an alternative to TCP and UDP in a port driver, given a programming example provided by Lambda? The example code has basically a connect a send and a receive routine. Any suggestions? Burkhard -- Dr. Burkhard Kolb KP1 / GSI E-Mail: [email protected] Tel: +49-(6159)-71-2667 / Fax: +49-(6159)-71-2185 Gesellschaft für Schwerionenforschung mbH Planckstraße 1 / D-64291 Darmstadt / www.gsi.de Gesellschaft mit beschränkter Haftung Sitz der Gesellschaft: Darmstadt Handelsregister: Amtsgericht Darmstadt, HRB 1528 Geschäftsführer: Professor Dr. Horst Stöcker Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
