1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asyn driver question: raw socket support
To: "Burkhard Kolb" <[email protected]>, <[email protected]>
Date: Tue, 12 Aug 2008 08:24:24 -0500
Hi Burkhard,
That should not be too difficult.  I have asyn port drivers that communicate with the Canberra AIM module, which speaks a low-level Ethernet protocol (IEEE 802.2 LLC Extended SNAP protocol).  I have used both an LLC socket driver on recent versions of Linux, and the "libpcap" and "libnet" libraries on Windows and older versions of Linux.  On vxWorks I've used both the older etherLib routines and the newer muxLib routines.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Burkhard Kolb
Sent: Tuesday, August 12, 2008 6:47 AM
To: '[email protected]'
Subject: asyn driver question: raw socket support
we have bought some Lambda Gen 8-180/LAN power supplies, which look from
the documentation "practically" the same as the power supplies from Agilent.
Nevertheless they use as low level protocol their private raw socket
interface, which involves fiddling with the packet headers, etc.
How difficult would it be to implement this as an alternative to TCP and
UDP in a port driver, given a programming example provided by Lambda?
The example code has basically a connect a send and a receive routine.
Any suggestions?
Burkhard
Dr. Burkhard Kolb
KP1 / GSI
E-Mail: [email protected]
Tel: +49-(6159)-71-2667 / Fax: +49-(6159)-71-2185
Gesellschaft für Schwerionenforschung mbH
Planckstraße 1 / D-64291 Darmstadt / www.gsi.de
Gesellschaft mit beschränkter Haftung
Sitz der Gesellschaft: Darmstadt
Handelsregister: Amtsgericht Darmstadt, HRB 1528
Geschäftsführer: Professor Dr. Horst Stöcker
Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph
Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
asyn driver question: raw socket support Burkhard Kolb
Prev: asyn driver question: raw socket support Burkhard Kolb
Next: Re: Scan Time Definitions David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EPICS Gateway question Kevin Tsubota
