1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS Gateway question
To: <[email protected]>
Date: Tue, 12 Aug 2008 10:27:39 -1000
I’m working on deployment of an EPICS Gateway version 2.0.3.0 in our system here.  I have the gateway running on a solaris-8 computer built against EPICS R3.14.9 with gcc 3.3.6.   The gateway is serving 2 VxWorks IOCs on a separate VLAN running EPICS R3.13.10 and VxWorkd 5.3.1.
According to the following description for serverPostRate:
> This is the rate in Hz at which events are posted to CAS. If the Gateway is keeping up, this will be very close to the serverEventRate. If not, it will be higher and all posted events will not have been processed.
It’s not good when the serverPostRate is higher than the serverEventRate. When I look my gateway stats I see that my servoPostRate is a lot higher than my serverEventRate, sometimes by as much as 2x, see attached gateway_rates.pdf.  The data was logged once every 10sec.  My load and cpu frac seems okay, see attached gateway_load.pdf.
Is there a way see what’s causing this and what can I do about it?
Thank you in advance.
Kevin Tsubota
W.M. Keck Observatory
Attachment: gateway_rates.pdf
Description: gateway_rates.pdf
Attachment: gateway_load.pdf
Description: gateway_load.pdf
Re: EPICS Gateway question Ralph Lange
Re: EPICS Gateway question Martin L. Smith
Re: EPICS Gateway question Dirk Zimoch
Prev: Re: Scan Time Definitions Andrew Johnson
Next: "device clear" in asyn/Gpib support. Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: asyn driver question: raw socket support Mark Rivers
Next: Re: EPICS Gateway question Ralph Lange
