I have a device through vxi-11 over ethernet. I need to send "device clear" message/command to this device to cancel an operation. I use an asyn/GP-IB/vxi-11 based device support and set gpib command table entry as: {&DSET_BO, GPIBDCL, IB_Q_HIGH, NULL, NULL, 0, 0, NULL, 0, 0, NULL, NULL, NULL }. This setup send a DCL universal command to the device through vxi-11 "device_docmd" rpc function. Unfortunately, our device does not support this method. The device just accept "device_clear" rpc call but not "DCL universal command". In the current asyn package, each IFC and REN has an entry in an asynGpibPort structure, but DCL(Device Clear) is treated as one of universal commands. It would be possible to introduce a new entry in asnyGpibPort for DCL and call "device_clear" rpc function in the handler for vxi-11. But I'm not quite sure if it does not break existing applications. I would appreciate any comments or suggestions to solve this problem. Thank you for reading this message. Regards, Noboru Yamamoto EPICS group, Acclerator Lab. KEK, JAPAN
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
