1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Build Question
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Thu, 21 Aug 2008 09:53:55 +0200
Hi David,
We have the sources in CVS. Whenever we build something (base or drivers), we check out what we need to our home directory and build it locally. Then the O.* directories are local which does not matter because they keep only temporary files. I have set INSTALL_LOCATION so that the base and driver libraries and headers are installed to a central place. Actually, I build base only once where the install location is writable. "Normal" development systems for drivers and IOCs see a read-only installation of base. Originally we did that with NFS but run into some problems when installing new (host) libraries while the same library is in use on an other NFS client. We changed to a system where base is locally installed from a tar or rpm.
We also keep the driver libraries and headers in a central place. But for drivers I use a completely different build system because I have to build the drivers not only for different architectures in parallel but even for three different EPICS base versions (3.13.9, 3.13.10 and 3.14.8). The EPICS build system was not designed for this.
Dirk
David Dudley wrote:
Is there a way to setup the build system so that the
O.<$EPICS_HOST_ARCH> directories are in another location?
I'm building for 3 different architectures, and I'd like to put the
EPICS source on a single (hopefully!) write protected NFS server, and
link to it when I need access to build, but would rather not have the
client machine writing directories on the server if I can get away with
it.
David
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
Build Question David Dudley
Prev: Fwd: Mail delivery failed: returning message to sender Benjamin Franksen
Next: Re: EPICS Gateway question Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Build Question Benjamin Franksen
Next: Loosing half the monitor callbacks Dehong Zhang
