On Thursday 07 August 2008 21:10, Susanna Jacobson wrote:
> In VxWorks 5.2 and previous, there was an unsupported tool called
> 'shadow', a shell script that would set up a local directory structure
> with each file replaced by a symbolic link to the one in the dir being
> shadowed. It was written by Roger Rohrbach to do exactly what David
> Dudley needs to do. I don't know right off hand how someone would obtain
> it other than from an ancient VxWorks distribution.
On our linux machine we have a tool called 'lndir'. From the man page:
The lndir program makes a shadow copy todir of a directory tree
fromdir, except that the shadow is not populated with real files but
instead with symbolic links pointing at the real files in the fromdir
directory tree. This is usually useful for maintaining source code for
different machine architectures. You create a shadow directory con-
taining links to the real source, which you will have usually mounted
from a remote machine. You can build in the shadow tree, and the
object files will be in the shadow directory, while the source files in
the shadow directory are just symlinks to the real files.
Cheers
Ben
"Programming = Mathematics + Murphy's Law" (E.W.Dijkstra)
- Build Question David Dudley
- Re: Build Question Andrew Johnson
- Re: Build Question Susanna Jacobson
Re: db question about S7-PLC driver Dirk Zimoch
Re: PV Gateway Dirk Zimoch
<2008>
2025
2026
Re: Build Question Dirk Zimoch
<2008>
2025
2026
