1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Build Question
To: [email protected]
Date: Thu, 07 Aug 2008 12:10:54 -0700
In VxWorks 5.2 and previous, there was an unsupported tool called 'shadow', a shell script that would set up a local directory structure with each file replaced by a symbolic link to the one in the dir being shadowed. It was written by Roger Rohrbach to do exactly what David Dudley needs to do. I don't know right off hand how someone would obtain it other than from an ancient VxWorks distribution.
Susanna
Andrew Johnson wrote:
You might be able to use some kind of overlay filesystem to provide the local writable directories; Linux has this capability, and I believe Solaris does too but I don't know how to set one up.
I'm building for 3 different architectures, and I'd like to put the
EPICS source on a single (hopefully!) write protected NFS server, and
link to it when I need access to build, but would rather not have the
client machine writing directories on the server if I can get away with
it.
Unfortunately we didn't design the EPICS build system for that particular model; the model we *did* design for is the one where your install directories are elsewhere, but in our model the build hosts have to be able to write to the source filesystem. If you don't want to allow writes to the NFS filesystem it might be simpler to have three separate copies of the source code (which you could copy or rsync off the NFS server).
- Andrew
-- ======================================================================== Susanna Jacobson MS 7-222 [email protected] Lawrence Berkeley National Laboratory VOICE: (510) 486-7801 1 Cyclotron Road FAX: (510) 486-7374 Berkeley, CA 94720-8225 ========================================================================
Re: Build Question Benjamin Franksen
Build Question David Dudley
Re: Build Question John Hammonds
Re: Build Question Pete Jemian
Re: Build Question Andrew Johnson
Prev: Re: Build Question Andrew Johnson
Next: RE: EPICS support for PI C-862 Mercury motor controller Isenegger Andreas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Build Question Benjamin Franksen
