1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PV Gateway
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Thu, 21 Aug 2008 09:32:45 +0200
Hi David,
I think, the two headers were supposed to be "private" to cas. But since the gateway needs them the base Makefile should be modified to install them. That's what I did and it works fine. However I didn't try 3.14.9. but run with 3.13.8.2.
I have added a bug report to Mantis (http://www.aps.anl.gov/epics/mantis/main_page.php).
Someone could add that information to the gateway documentation. :-)
Dirk
David Dudley wrote:
At least to build the gateway, you need casCtx.h and casHdrLargeArray.h
(think I got that one right?).
Looking at src/cas/build/Makefile, did they perhaps get left out?
I added them into the file and rebuilt base, and they got copied into
the destination.  Should all the include files be listed, or is there
some subset, or was that a mistake?
Gateway now builds correctly, and looks like it's going.
David
"David Dudley" <[email protected]> 8/20/2008 5:49 PM >>>
Well, getting closer, but still a mystery.
For some reason, when I build the system from a blank start (did make
clean before running make),  the build dances all around the 'generic'
directory in the src/cas directory, but never enters it, or copies
anything from it into the destination.
Have I made a configure error?????
David
"David Dudley" <[email protected]> 8/20/2008 5:30 PM >>>
I actually found a file, in my base source directory, by that name,
but
it didn't get copied into the installation include files.  Can I just
copy it over there, or is there something else I also need to do?
David
"David Dudley" <[email protected]> 8/20/2008 5:27 PM >>>
I'm trying to compile Gateway 2_0_3_0, but I keep getting a failure
for
casCtx.h when I try to compile.
I've got the 3.14.9 version installed (at least I think so), but the
only file I have in the includes is: casdef.h.
Did I miss something?
David
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:826-1265
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
TITLE:Functional Analyst
END:VCARD
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
Re: PV Gateway Andrew Johnson
PV Gateway David Dudley
Re: PV Gateway David Dudley
Prev: Re: Build Question Benjamin Franksen
Next: Fwd: Mail delivery failed: returning message to sender Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: PV Gateway David Dudley
Next: Re: PV Gateway Andrew Johnson
