What version of gcc are you using? It seems that it can't locate the
standard headers.
thanks,
tom
On Aug 21, 2008, at 4:37 AM, Umashankar Panda wrote:
Dear All,
I am facing this problem while compling WebCA 1.1.0. What can be the
probable cause?
With regards
U.Panda
VECC, India
umashankar@umashankar:~/epics/extensions/src/webca-1.1.0> make
make -C configure install
make[1]: Entering directory
`/home/umashankar/epics/extensions/src/webca-1.1.0/configure'
perl /home/umashankar/epics/base-3.14.9/configure/tools/
convertRelease.pl
-h linux-x86 checkRelease
make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86 install
make[2]: Entering directory
`/home/umashankar/epics/extensions/src/webca-1.1.0/configure/O.linux-
x86'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory
x86'
make[1]: Leaving directory
make -C npca install
`/home/umashankar/epics/extensions/src/webca-1.1.0/npca'
make -C src install
`/home/umashankar/epics/extensions/src/webca-1.1.0/npca/src'
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[3]: Entering directory
`/home/umashankar/epics/extensions/src/webca-1.1.0/npca/src/O.linux-
x86'
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux
-D_REENTRANT -DEMBED_CA_REPEATER -I../../../gecko-sdk/include -ansi
-O3 -Wall -g -fPIC -I. -I.. -I../../../include/os/Linux
-I../../../include
-I/home/umashankar/epics/base-3.14.9/include/os/Linux
-I/home/umashankar/epics/base-3.14.9/include ../plugin.cpp
../plugin.cpp: In function 'char* stringValue(const NPString&)':
../plugin.cpp:48: error: 'strncpy' was not declared in this scope
../plugin.cpp: In member function 'virtual bool
ScriptablePluginObject::GetProperty(void*, NPVariant*)':
../plugin.cpp:354: error: 'strdup' was not declared in this scope
../plugin.cpp:354: error: 'strlen' was not declared in this scope
../plugin.cpp:359: error: 'strdup' was not declared in this scope
../plugin.cpp:359: error: 'strlen' was not declared in this scope
../plugin.cpp: In function 'void push_connection_event(CPlugin*,
eventUserArg*, connection_handler_args&)':
../plugin.cpp:393: error: 'strlen' was not declared in this scope
../plugin.cpp: In function 'void event_handler(evargs)':
../plugin.cpp:474: error: 'memcpy' was not declared in this scope
../plugin.cpp: In function 'int parseArrayObject(NPP_t*, NPObject*,
short int&, int&, void*&)':
../plugin.cpp:646: error: 'strncpy' was not declared in this scope
ScriptablePluginObject::Invoke(void*, const NPVariant*, uint32_t,
NPVariant*)':
../plugin.cpp:787: error: 'strlen' was not declared in this scope
../plugin.cpp:834: error: 'strlen' was not declared in this scope
../plugin.cpp:957: error: 'strlen' was not declared in this scope
../plugin.cpp:986: error: 'strlen' was not declared in this scope
../plugin.cpp:1185: error: 'strlen' was not declared in this scope
../plugin.cpp:1279: error: 'memcpy' was not declared in this scope
../plugin.cpp:1290: error: 'memcpy' was not declared in this scope
../plugin.cpp:1316: error: 'strdup' was not declared in this scope
../plugin.cpp:1316: error: 'strlen' was not declared in this scope
../plugin.cpp:1323: error: 'strdup' was not declared in this scope
../plugin.cpp:1323: error: 'strlen' was not declared in this scope
../plugin.cpp:1353: error: 'strlen' was not declared in this scope
../plugin.cpp:1369: error: 'strlen' was not declared in this scope
ScriptablePluginObject::InvokeDefault(const NPVariant*, uint32_t,
NPVariant*)':
../plugin.cpp:1427: error: 'strdup' was not declared in this scope
../plugin.cpp:1427: error: 'strlen' was not declared in this scope
ArrayObject::GetProperty(void*, NPVariant*)':
../plugin.cpp:1898: error: 'strdup' was not declared in this scope
../plugin.cpp:1898: error: 'strlen' was not declared in this scope
CTRLObject::GetProperty(void*, NPVariant*)':
../plugin.cpp:2037: error: 'strdup' was not declared in this scope
../plugin.cpp:2037: error: 'strlen' was not declared in this scope
../plugin.cpp:2039: error: 'strdup' was not declared in this scope
../plugin.cpp:2039: error: 'strlen' was not declared in this scope
../plugin.cpp:2093: error: 'memcpy' was not declared in this scope
make[3]: *** [plugin.o] Error 1
make[3]: Leaving directory
x86'
make[2]: *** [install.linux-x86] Error 2
make[1]: *** [src.install] Error 2
make: *** [npca.install] Error 2
- Problem in compiling WebCA Umashankar Panda
Re: Motor home status Kurt Goetze
EPICS in Industrial setting David Dudley
<2008>
2025
2026
Re: Problem in compiling WebCA Stefan Heim
<2008>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
