1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem in compiling WebCA
To: Umashankar Panda <[email protected]>
Cc: [email protected]
Date: Wed, 03 Sep 2008 17:43:46 +0200
On Thu, 2008-08-21 at 14:07 +0530, Umashankar Panda wrote:
> I am facing this problem while compling WebCA 1.1.0. What can be the
> probable cause?
> /usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux
> -D_REENTRANT -DEMBED_CA_REPEATER  -I../../../gecko-sdk/include  -ansi
> -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux
> -I../../../include
> -I/home/umashankar/epics/base-3.14.9/include/os/Linux
> -I/home/umashankar/epics/base-3.14.9/include        ../plugin.cpp
> ../plugin.cpp: In function 'char* stringValue(const NPString&)':
> ../plugin.cpp:48: error: 'strncpy' was not declared in this scope
> ../plugin.cpp: In member function 'virtual bool
> ScriptablePluginObject::GetProperty(void*, NPVariant*)':
> ../plugin.cpp:354: error: 'strdup' was not declared in this scope
> ../plugin.cpp:354: error: 'strlen' was not declared in this scope
> ../plugin.cpp:359: error: 'strdup' was not declared in this scope
> ../plugin.cpp:359: error: 'strlen' was not declared in this scope
> ../plugin.cpp: In function 'void push_connection_event(CPlugin*,
looks like you are very likely using gcc >= 4.1 (check output of "g++
--version") and are missing a
#include <cstring>
line at the top of npca/src/plugin.cpp . Just put the line there and it
will compile.
HTH,
-Stefan
Problem in compiling WebCA Umashankar Panda
Prev: Alias PV gateway seems unreliable Angelic Ebbers
Next: Re: RTEMS vs VxWorks Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem in compiling WebCA Tom Pelaia
Next: EPICS in Industrial setting David Dudley
