1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PV Gateway
To: [email protected]
Cc: David Dudley <[email protected]>
Date: Thu, 21 Aug 2008 09:53:24 -0500
On Thursday 21 August 2008 09:40:27 I wrote:
> The latest version of the gateway in CVS has the following added to the
> gateway/Makefile which completely avoids the need to install those files:
> # need access to casCtx.h
> USR_INCLUDES += -I$(EPICS_BASE)/src/cas/generic
I think I lied; those lines are already in David's version of the gateway code
(2-0-3-0) but they won't work if his EPICS_BASE is pointing to a tree that
was installed in a different location to the source code by setting
INSTALL_LOCATION in the base/configure/CONFIG_SITE file.
Manually installing the private header files like David did was probably the
easiest way for him to fix the problem at the moment, although he could also
have modified the gateway's Makefile to point that -I option to the original
source for Base.  We need to get the additional APIs included in CAS to fix
this properly.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
Re: PV Gateway Maren Purves
PV Gateway David Dudley
Re: PV Gateway Dirk Zimoch
Re: PV Gateway Andrew Johnson
Prev: Re: PV Gateway David Dudley
Next: Re: PV Gateway Gasper Jansa
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: PV Gateway Maren Purves
