Andrew is right, I have added the "hack" to the gateway Makefile to get the headers from EPICS_BASE. But as David has seen, it does not work if INSTALL_LOCATION of base has been modified. We have the same situation here at PSI. Thus, I had to install the header. At the moment, there is no proper way to get the header information automatically. And I think we need some way. One should probably reconsider which information is really "private" and which not. For example the event mask of the client is not really a secret. Why should the server not find out about it? But an official API is missing. Thus, the only way is to look into the "private" parts of cas. It is in particular this code (from gateVc.cc) which requires access to casCtx.h: caStatus gateVcData::read(const casCtx& ctx, gdd& dd)
/* This is to obtain mask from client */
if(ctx.getMsg()->m_cmmd == CA_PROTO_EVENT_ADD){
struct mon_info *pMonInfo = (struct mon_info *) ctx.getData();
//If build with R3.14.9 next two lines must be switched
// ca_uint16_t caProtoMask = AlignedWireRef < epicsUInt16 >(pMonInfo->m_mask);
ca_uint16_t caProtoMask = epicsNTOH16 (pMonInfo->m_mask); if (caProtoMask & DBE_LOG) {
client_mask = DBE_LOG;
}It would be nice to have a getEventMask() method instead. Should I add this to Mantis? Also note that the code needs modification for R3.14.9 because of an other "private" thing in base: Byte order handling. (Well, it's not private in the sense that the headers are not available but in the sense that functions have disappeared and have been replaced with other functions. I have to assume it they where meant to be private because using them break the code when upgrading EPICS base. It would also be nice to have an "official" byte order API in libCom (for C, not only C++) because not only channel access needs it. Also some drivers may be interested in the byte order and need to convert. Should I add this to Mantis? BTW: I have requested earlier that byte order is either detected automatically (from endian.h where it exists) or can be configured in the CONFIG_<arch>_something file. Having to hack code like the following (found in base-3.14.9/include/os/Linux/osdWireFormat.h) is no good style: #if defined (_M_IX86) || defined (_X86_) || defined (__i386__) || defined (_X86_64_) || defined (_M_AMD64) # define EPICS_LITTLE_ENDIAN #elif ( defined (__ALPHA) || defined (__alpha) ) # define EPICS_LITTLE_ENDIAN #elif defined (__arm__) # define EPICS_LITTLE_ENDIAN #else # define EPICS_BIG_ENDIAN #endif Will this be fixed in 3.14.10? Should I add this to Mantis? Best regards, Dirk Andrew Johnson wrote: On Thursday 21 August 2008 02:32:45 Dirk Zimoch wrote:I think, the two headers were supposed to be "private" to cas. But since the gateway needs them the base Makefile should be modified to install them. That's what I did and it works fine. However I didn't try 3.14.9. but run with 3.13.8.2.
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
