1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Waveform Records
To: "David Dudley" <[email protected]>, <[email protected]>
Date: Thu, 4 Sep 2008 14:14:45 -0400
Some issues ---
1) waveforms are just arrays. You're device support can fill it any way you like.
2) there is a circular buffer record that already does this either ring buffer - or successive averaging or keep high or low for each sample.
3) we do not queue the array - so if your client is not getting them fast enough in monitoring - then you will loose old arrays. You may even get half of one and half of another. This system needs to be set up carefully.
4) There is a subarray record for just reading an area of interest.
5) we did not do the meta data correctly - so no indication of the unit of time between samples within the array.
-----Original Message-----
Sent: Thu 9/4/2008 2:04 PM
To: [email protected]
Subject: Waveform Records
Need a little 'training' on waveform records....
1. With a waveform record, with each scan of the I/O device, does the
device read in a single sample, or a whole waveform?
2. Can waveforms be setup to operate in a continuous FIFO manner?  In
other words, a sliding window of data items collected over time?
3. Can 'edm' display a waveform record, and if so, how?  If 'edm' can't
display them, is there a program that can?
David
RE: Waveform Records David Dudley
Prev: Waveform Records David Dudley
Next: RE: Waveform Records David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
