Maybe a little background would help.
I've got a PV where they want to watch real-time historical information
over the past 4 hours.
The PLC that acquires that PV stores this information in a FIFO buffer
once every 60 seconds, with time stamp information should I require it
(the PLC actually has a buffer that stores the last 48 hours, which
means I actually have 2880 samples, all available at any time). The
desire is to 'see' that information in graphical form if possible, or in
a table form if not.
David
>>> "Dalesio, Leo" <[email protected]> 9/4/2008 1:14:45 PM >>>
Some issues ---
1) waveforms are just arrays. You're device support can fill it any way
you like.
2) there is a circular buffer record that already does this either ring
buffer - or successive averaging or keep high or low for each sample.
3) we do not queue the array - so if your client is not getting them
fast enough in monitoring - then you will loose old arrays. You may even
get half of one and half of another. This system needs to be set up
carefully.
4) There is a subarray record for just reading an area of interest.
5) we did not do the meta data correctly - so no indication of the unit
of time between samples within the array.
-----Original Message-----
Sent: Thu 9/4/2008 2:04 PM
To: [email protected]
Subject: Waveform Records
Need a little 'training' on waveform records....
1. With a waveform record, with each scan of the I/O device, does the
device read in a single sample, or a whole waveform?
2. Can waveforms be setup to operate in a continuous FIFO manner? In
other words, a sliding window of data items collected over time?
3. Can 'edm' display a waveform record, and if so, how? If 'edm'
can't
display them, is there a program that can?
David
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:826-1265
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
TITLE:Functional Analyst
END:VCARD
- RE: Waveform Records Dalesio, Leo
- RE: Waveform Records Mark Rivers
- Waveform Records David Dudley
<2008>
2025
2026
<2008>
2025
2026
