1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Gateway problem .... more info
To: <[email protected]>
Date: Thu, 4 Sep 2008 12:06:55 -1000
>From studying the debugging logs, it looks like some channels
continuously report:
"write() pv not ready" when a client tries to write to them through the
gateway.
Then (usually triggered by a caget from a terminal) they become ready
"vcAdd() connecting -> ready"
After which a large backlog of writes are allowed through.
In some cases, I looks like a write to an input field is put on hold as
the channel isn't "ready" and then when a write to the Directive field
goes through, the input field becomes ready and the input is written
after the directive ... causing the "out of order", and thus failed,
commands.
What handshake between the ioc and the gateway is failing to set some
channels ready while others work properly?
Some help here would be greatly appreciated.
Angelic
Re: Gateway problem .... more info Dirk Zimoch
Prev: Re: sseq link problem on Linux Maren Purves
Next: Re: Gateway problem .... more info Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: sseq link problem on Linux Shepherd, EL (Emma)
