1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Gateway problem .... more info
To: tech-talk <[email protected]>
Date: Fri, 05 Sep 2008 14:03:47 +0200
Hi Angelic,
Do you write to one of those records that take a long time to complete a
ca_put_callback? Many SynApps records behave like that. For example the motor
record does not become "ready" until motion has finished.
Dirk
Angelic Ebbers wrote:
From studying the debugging logs, it looks like some channels
continuously report:
"write() pv not ready" when a client tries to write to them through the
gateway.
Then (usually triggered by a caget from a terminal) they become ready
"vcAdd() connecting -> ready"
After which a large backlog of writes are allowed through.
In some cases, I looks like a write to an input field is put on hold as
the channel isn't "ready" and then when a write to the Directive field
goes through, the input field becomes ready and the input is written
after the directive ... causing the "out of order", and thus failed,
commands.
What handshake between the ioc and the gateway is failing to set some
channels ready while others work properly?
Some help here would be greatly appreciated.
Angelic
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
Gateway problem .... more info Angelic Ebbers
Prev: Gateway problem .... more info Angelic Ebbers
Next: Re: sseq link problem on Linux Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Gateway problem .... more info Angelic Ebbers
