Hi Carl,
On Monday 08 September 2008 13:51:57 Carl Schumann wrote:
> I am working with EPICS base and EDM. While I don't intend to modify
> either source, I would like to view the EPICS and EDM source in the
> debugger when working on my code. (My code extends EDM via edm's
> -addpv.) Is there a standard way to cause all of EPICS base and EDM to
> be built with debug options, e.g., -g and perhaps no optimization.
Yes, edit your base/configure/CONFIG_SITE file and set HOST_OPT=NO. If you're
cross-compiling to vxWorks or RTEMS, set CROSS_OPT=NO instead/as well. Then
rebuild everything. You can do this on a per-architecture basis by changing
an appropriate os/CONFIG_SITE.* file instead.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- EPICS base and/or EDM with debugging info Carl Schumann
Re: About Runnig of epics Dirk Zimoch
<2008>
2025
2026
RE:- Epics Developer Chris Joseph
<2008>
2025
2026
