1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: About Runnig of epics
To: Selim Ünal <[email protected]>
Cc: [email protected]
Date: Tue, 09 Sep 2008 10:41:02 +0200
Hi Selim,
The "unknown" architecture is a hint that EPICS_HOST_ARCH is not set. I think that should have been done in ./setup.sh. How did you use this file?
Wrong:  ./setup.sh
Correct: . ./setup.sh
In order to set environment variables in your current shell, you have to _source_ the setup file, not to _call_ it.
Dirk
Selim Ünal wrote:
I installed the epics in system of linux(debian) with command of ./setup.sh .Then , I write " startIoc.sh " or "startMedm.sh" , I dont start epics. Could you help me? It give error that is "Virtual Linac doesn't support this architecture:Linux unknown"
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
About Runnig of epics Selim Ünal
Prev: Re: EPICS base and/or EDM with debugging info Andrew Johnson
Next: Re: About Runnig of epics Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: About Runnig of epics Selim Ünal
