1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA Gateway environment variable configuration
To: Carl Schumann <[email protected]>
Cc: [email protected]
Date: Mon, 22 Sep 2008 10:11:37 +0200
Hi Carl,
Many of those variables become specified when you use the command line parameters -sip, -sport, -cip, -cport.
You probably want to set the variables
EPICS_CA_MAX_ARRAY_BYTES=<the largest array you have in your whole system>
EPICS_CAS_BEACON_ADDR_LIST=<all networks where clients may run>
On a 32 bit machine you also probably want to limit the stack size per thread to allow a large number of threads:
ulimit -s 2048
Best regards,
Dirk
Carl Schumann wrote:
I am trying to get a CA gateway going. The gateway logs the following:
Starting EPICS CA gateway
Sep 19 16:35:28 PV Gateway Version 2.0.3.0 [Sep 11 2008 07:53:33]
EPICS 3.14.9 PID=15076
EPICS_CA_ADDR_LIST=cag-hins-1.fnal.gov
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_CA_SERVER_PORT=Not specified
EPICS_CA_MAX_ARRAY_BYTES=Not specified
EPICS_CAS_INTF_ADDR_LIST=clx74.fnal.gov
EPICS_CAS_SERVER_PORT=Not specified
EPICS_CAS_IGNORE_ADDR_LIST=Not specified
Running as user schumann on host clx74.fnal.gov
Statistics PV prefix is clx74.fnal.gov
It reports many environment variables as "Not specified". Should I be specifying them or will reasonable defaults be used?
Carl Schumann
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
CA Gateway environment variable configuration Carl Schumann
Prev: CA Gateway environment variable configuration Carl Schumann
Next: StreamDevice 2.4 released Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
