1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: StreamDevice 2.4 released
To: tech-talk <[email protected]>
Date: Mon, 22 Sep 2008 10:55:34 +0200
Hi all,
StreamDevice version 2.4 is now available at http://epics.web.psi.ch/software/streamdevice/
This version is compatible with asyn 4.10 and base 3.14.10.
Some issues with "I/O Intr" have been fixed. The most severe problem was a stack overflow on some systems with fixed small stack sizes (vxWorks, RTEMS) when multi-lime input was received.
A signed long conversion problem on 64 bit machines has been fixed for ai, ao, longin, longout records.
New formats (some have already been available as patches)
%R -- raw float/double
%0r -- raw unsigned integer
%m -- a strange mantissa-exponent format without . or e
%#b and %#B -- little endian bit order for %b and %B
Thanks to all bug reporters.
Dirk
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
Re: StreamDevice 2.4 released Rod Nussbaumer
Prev: Re: CA Gateway environment variable configuration Dirk Zimoch
Next: CA gateway and CA beacons Carl Schumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: StreamDevice 2.4 released Rod Nussbaumer
