1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: StreamDevice 2.4 released
To: Rod Nussbaumer <[email protected]>
Date: Wed, 24 Sep 2008 09:43:01 +0200
Rod Nussbaumer wrote:
Dirk Zimoch wrote:
Hi all,
StreamDevice version 2.4 is now available at http://epics.web.psi.ch/software/streamdevice/
This version is compatible with asyn 4.10 and base 3.14.10.
Does this imply any incompatibilities with earlier versions of asyn and/or EPICS base, or is this simply unknown? In particular, I am interested in asyn 4-9 and EPICS 3.14.8.2.
Thanks.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada
No. I still use EPICS 3.14.8.2 and asyn 4-8. StreamDevice requires base 3.14.6 or higher and asyn 4-3 or higher.
BTW: There was a problem with RawFloatConverter.cc on RTEMS and some other systems. That should be fixed now. Instead of providing a patch I have rebuild version 2.4. Please download again.
Dirk
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
StreamDevice 2.4 released Dirk Zimoch
Re: StreamDevice 2.4 released Rod Nussbaumer
Prev: Re: EPICS perl tools in 3.14.10-pre1 Andrew Johnson
Next: Re: ASYN R4.10 Release Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: StreamDevice 2.4 released Rod Nussbaumer
Next: CA gateway and CA beacons Carl Schumann
