1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EDM font sizes
To: [email protected]
Date: Fri, 26 Sep 2008 12:17:00 -0400
Try adding this to fonts.list instead:
-adobe-times-medium-r-normal--*-340-100-100-p-*-iso8859-1
On my computer here this looks pixellated, apparently because it's not a scalable font. It shows up in the list that appears when I select View->Font Mappings from the edm main window as
-adobe-times-medium-r-normal--47-340-100-100-p-0-iso8859-1
I'm not sure if or how a better-looking scalable version might be used instead.
You might have better luck specifying your fonts using the "Version 3" font-list format detailed in the EDM documentation rather than adding on to the "Version 1" format-file included with EDM.
-Kevin
I am trying to add more fonts to EDM. Take the following font for example:
-adobe-times-medium-r-normal--34-240-100-100-p-170-iso8859-1 I added above line to /afs/slac/g/lcls/tools/edm/config/fonts.list and verified that EDMFILES points to the right location:
[jingchen@lcls-dev2 config]$  printenv EDMFILES
However, I don't see the font showing up when I bring up EDM. Am I missing any?
Is there any log option for EDM that I can track?
Jingchen
Prev: Re: ASYN R4.10 Release - code depreciation Dirk Zimoch
Next: Re: ASYN R4.10 Release - code depreciation Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EDM font sizes Zhou, Jingchen
Next: epicsThreadSleep() and epicsThreadSleepQuantum() Mark Rivers
