1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ASYN R4.10 Release - code depreciation
To: [email protected]
Date: Fri, 26 Sep 2008 12:24:52 -0500
On Friday 26 September 2008 04:22:32 Dirk Zimoch wrote:
> The gnu compiler has an extension called attributes. One can mark a
> function, variable, or type with __attribute__((deprecated)). (For other
> compilers, define an empty macro __attribute__(x) for compatibility.) This
> produces a compiler warning when the function or variable is used.
For R3.14.10 I've just added EPICS_DEPRECATED to compilerDependencies.h which
is where we normally put this kind of macro.  On GNU compilers it expands to
__attribute__((deprecated)), on other compilers it is empty.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
RE: ASYN R4.10 Release - code depreciation Pearson, MR (Matthew)
Re: ASYN R4.10 Release - code depreciation Dirk Zimoch
Prev: Re: EDM font sizes Kevin Anderson
Next: Re: SIemens PLCs Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ASYN R4.10 Release - code depreciation Dirk Zimoch
Next: Modbus Mark Rivers
