1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Base R3.14.10-RC1 Released
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 02 Oct 2008 11:56:11 -0400
On 9/29/08 6:38 PM, Andrew Johnson wrote:
snip
> Comments, bug reports, questions and thanks should go to tech-talk; monetary
> expressions of gratitude to the Core Developer's Beer/Wine Fund at the INFN
> meeting.
Hi, Andrew.
Thanks for all your work toward the 3.14.10 release!
A few comments.
Platform: darwin-x86 (Mac OS X 10.5.5); gcc 4.0.1
1. I noticed the distribution contains .cvsignore files.  These can
trivially be removed before packaging on a modern UNIX environment with
something like:
  $ find . -name '.cvsignore' -print0 | xargs -0 rm
2. I get various compiler warnings when building.  This is not new, but
if you want to see them, search for "warning" in my build log at
  http://www.imca.aps.anl.gov/~jlmuir/epics-3.14.10-build.txt
3. The host platforms list in the README at
  http://www.aps.anl.gov/epics/base/R3-14/10-docs/README.html
does not match the list in configure/CONFIG_SITE.  For example,
darwin-x86 and others are not listed in the README.
4. I was hoping for an easy way to run all tests for my platform (such
as "make test" from the EPICS base root directory), but I couldn't find
it.  I ended up doing the following:
  $ cd src/libCom/O.darwin-x86
  $ for each in `ls -1 *.t`; do perl $each; done
Is there a better way?
All the libCom tests seemed to pass.  A log, if you're interested, is at
  http://www.imca.aps.anl.gov/~jlmuir/epics-3.14.10-libCom-test.txt
5. It would be nice if the EPICS Application Developer's Guide used
links (hyper-references?) in the table of contents.  This would make it
easy to jump to a section of interest.  Delta Tau does this with most of
their documentation and I've found it to be pretty convenient.  Here's
an example:
  http://www.deltatau.com/fmenu/ACC-26A.PDF
If your PDF viewer supports it, you can click on a section in the table
of contents and jump right to it.
It looks like you're using Adobe FrameMaker 6.0 to create the
Application Developer's Guide.  Does FrameMaker support making the table
of contents with links like this?
Lewis
J. Lewis Muir
Software Engineer
IMCA-CAT/CARS
Re: Base R3.14.10-RC1 Released J. Lewis Muir
Re: Base R3.14.10-RC1 Released Andrew Johnson
Prev: Re: epicsThreadSleep() and epicsThreadSleepQuantum() J. Lewis Muir
Next: devStats - OSI version of devVxStats Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Base R3.14.10-RC1 Released Andrew Johnson
Next: Re: Base R3.14.10-RC1 Released J. Lewis Muir
