1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Base R3.14.10-RC1 Released
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 03 Oct 2008 10:50:55 -0400
On 9/29/08 6:38 PM, Andrew Johnson wrote:
snip
> Comments, bug reports, questions and thanks should go to tech-talk; monetary
> expressions of gratitude to the Core Developer's Beer/Wine Fund at the INFN
> meeting.
Hi, Andrew.
Unfortunately, I can't get it to compile on RHEL WS 3.  Here's the build
log:
  http://www.imca.aps.anl.gov/~jlmuir/epics-3.14.10-rhel3-build.txt
You can see that src/toolsComm/antelope is failing to build because it
can't find the Com library.  Looking earlier, it seems that src/libCom
didn't build correctly...it just installed header files, but didn't
compile and install the Com library.  I saw that it reported finding
EPICS version "3.14.10-".  Thinking that might be the problem, I  set
EPICS_CVS_SNAPSHOT in configure/CONFIG_BASE_VERSION to be empty:
  EPICS_CVS_SNAPSHOT=
Now it finds EPICS version "3.14.10", but it still fails in the same
way.  The version of GNU Make (3.79.1) is older than the release notes
say is required (3.81).  Could that be the problem?
The C/C++ compiler is GCC 3.2.3.
Lewis
Re: Base R3.14.10-RC1 Released Andrew Johnson
Prev: Re: Base R3.14.10-RC1 Released Benjamin Franksen
Next: Re: Base R3.14.10-RC1 Released Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
