1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Base R3.14.10-RC1 Released
To: [email protected]
Date: Fri, 3 Oct 2008 00:15:44 +0200
On Donnerstag, 2. Oktober 2008, Andrew Johnson wrote:
> Other warnings are from
> code generated by flex and/or antelope, which we didn't write and are not
> programs I want to look inside if I don't have to.
I recently discovered a nice alternative to yacc/bison/antelope which is
called Lemon, see http://www.hwaci.com/sw/lemon/ . It is used e.g. in
sqlite to parse SQL. Here are the highlights (from the home page):
 * Lemon using a different grammar syntax which is less prone to
   programming errors.
 * The parser generated by Lemon is both re-entrant and thread-safe.
 * Lemon includes the concept of a non-terminal destructor, which
   makes it much easier to write a parser that does not leak memory.
IIRC, EPICS has made changes to (its own copy of) antelope in order to
address points 2 and 3 above.
I should add that lemon creates code with a nice and clear procedure based
API, and that it does not contain a lexer generator (however, there is re2c
for that).
Cheers
Ben
Base R3.14.10-RC1 Released Andrew Johnson
Re: Base R3.14.10-RC1 Released J. Lewis Muir
Re: Base R3.14.10-RC1 Released Andrew Johnson
Prev: Re: devStats - OSI version of devVxStats Andrew Johnson
Next: Re: Base R3.14.10-RC1 Released J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Base R3.14.10-RC1 Released Andrew Johnson
