1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Process 'bo' on write?
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Mon, 06 Oct 2008 08:29:13 -1000
David,
any reason why you're not using the alarm handler?
Maren
David Dudley wrote:
I've got a PLC that handles alarm notifications. This PLC runs only 2 things - a 120DB horn, and the brightest strobe light you've ever seen in your life (OK, some of you guys have probably seen something brighter, just not me ;-).
When a NEW alarm comes in (which is a output BIT that writes to a PLC
control register), the PLC clears that bit, resets a couple of latching
relays, and then sets off the horn, and/or the strobe.  This happens
every time this bit is written as a '1'.  As long as the alarm bit in
EPICS is set, I don't want to output the bit to the PLC again.  Only
when the bit is initially set to a non-zero do I want to write to the
PLC.
Re: Process 'bo' on write? David Dudley
Re: Process 'bo' on write? Tim Mooney
Prev: October meeting: tarball for IRMIS application layer training Carcassi, Gabriele
Next: Re: Process 'bo' on write? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Process 'bo' on write? David Dudley
Next: Re: Process 'bo' on write? David Dudley
