1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Process 'bo' on write?
To: <[email protected]>
Date: Mon, 06 Oct 2008 09:18:39 -0500
The calcout method sounds like what I'm going to use for this function.
I was just wondering if there was another way (or a simpler one) to do
the same thing.
Yes, I could set up my device driver to only write changes to the
hardware, but one of the things I've been trying to accomplish is to NOT
come up with 50 different ways to do the same thing.  If there was
something already inside EPICS to accomplish this, then that's what I
would want to use, instead of coming up with my own interpretition.
My problem is this:
I've got a PLC that handles alarm notifications.  This PLC runs only 2
things - a 120DB horn, and the brightest strobe light you've ever seen
in your life (OK, some of you guys have probably seen something
brighter, just not me ;-).
When a NEW alarm comes in (which is a output BIT that writes to a PLC
control register), the PLC clears that bit, resets a couple of latching
relays, and then sets off the horn, and/or the strobe.  This happens
every time this bit is written as a '1'.  As long as the alarm bit in
EPICS is set, I don't want to output the bit to the PLC again.  Only
when the bit is initially set to a non-zero do I want to write to the
PLC.
The guys have acknowledge buttons and silence buttons to stop the light
and horn, but the alarm is still ON, and there are other indications of
the alarm that remain active.
If I were programming a PLC, I'd just use a 'positive one-shot' or
'diffentiator' to perform limiting the output, but I want to do this
inside EPICS instead.
>From my point of view, I want to only have the record process when the
value changes, either from 0-1, or from 1-0.
Got a couple of other things I need to work toward, but this is the
first one to become important (have to prevent the operation staff from
going blind and deaf, although sometimes I wonder ;-).
David
>>> Tim Mooney <[email protected]> 10/6/2008 8:49 AM >>>
David,  Do you really want the record to refrain from processing,
or is it sufficient that it refrain from writing to hardware?
If you just want the record to write only *changes* to hardware,
you can do this in device support.  If you want it to not process,
then I'm pretty sure no record can do this without outside help.
If a record were to decide whether or not to process based on the
value written to it, putNotify would not work for that record.
(I know because I wrote a record that did this, and decided to
abandon the tactic when putNotify was developed.)
I would use a calcout record to write to the output record, and
set the calcout record's OOPT field to "On Change".
David Dudley wrote:
> Is there a way for me to set a bo (or ao) record so that it only
> processes when it's value is changed?
> I've got a number of those records that I only need written to the
PLC
> when the value is changed.
> David
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:826-1265
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
TITLE:Functional Analyst
END:VCARD
Re: Process 'bo' on write? Maren Purves
Re: Process 'bo' on write? Andrew Johnson
Process 'bo' on write? David Dudley
Re: Process 'bo' on write? Tim Mooney
Prev: Re: Process 'bo' on write? Tim Mooney
Next: Re: problem of using Streamdevice Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Process 'bo' on write? Maren Purves
