1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: problem of using Streamdevice
To: [email protected]
Date: Mon, 06 Oct 2008 18:07:34 +0200
I will check if there is a bug in the implementation of %*1c. A NULL pointer for
the string is normal here because the string should be ignored. If it crashed it
seems to be a bug in my code.
Dirk
Silver wrote:
> hi, all:
>   I am just trying Streamdevice driver by Franksen's suggestion. Seems it's a flexabile way of controlling our equipment. But I met some problems, the ioc will crash quickly after starting.
> our streamdevice will response 8 bytes data in hex like "55 40 04 67 39 47 be e3". in the data, "67 39 47 be" is a float's 4 bytes. other bytes are header or crc. So I write my protocol file like this:
> # example stream protocol file
> #Terminator = CR LF;
> ReplyTimeout = 80000; # 10 sec is very long, for keyboard input
> ReadTimeout = 1000;   # also long for keyboard input
> # note the field access
> ai {
>     out 170 129 00 129;
>     in "%*3c%#R%*1c";
> my example.db is like this:
> # process this record to reload all stream protocols
> record (ai, "$(PREFIX):ai")
>     field (DESC, "An analog value")
>     field (DTYP, "stream")
>     field (INP,  "@example.proto ai terminal")
> #    field (PREC, "3")
> #    field (LINR, "LINEAR")
> #    field (ESLO, "0.000305180437934") # 20.0 / 0xffff
> #    field (EOFF, "-10")
> #    field (EGU,  "V")
>     field (SCAN, ".5 second")
> my example.cmd file:
> #!./streamApp
> dbLoadDatabase "O.Common/streamApp.dbd"
> streamApp_registerRecordDeviceDriver
> #where can protocols be located?
> epicsEnvSet "STREAM_PROTOCOL_PATH", ".:protocols:../protocols/"
> #setup the busses
> #example telnet style IP port setup
> drvAsynIPPortConfigure "terminal", "192.168.1.103:4001"
> #asynOctetSetInputEos "terminal",0,"\r\n"
> #asynOctetSetOutputEos "terminal",0,"\r\n"
> #example VXI11 (GPIB via IP) port setup
> #vxi11Configure "GPIB","ins023",1,5.0,"hpib"
> #load the records
> dbLoadRecords "example.db","PREFIX=DZ"
> #dbLoadRecords "scalcout.db","PREFIX=DZ"
> #lots! of debug output
> #var streamDebug 1
> #enable debug output
> var streamDebug 1
> iocInit
> my output of running ioc:
> ~/testApp/StreamDevice-2-4/streamApp>./example.cmd
> #!./streamApp
> #setup the busses
> #load the records
> #var streamDebug 1
> iocInit
> Starting iocInit
> ###  EPICS IOC CORE built on Sep 27 2008
> ###  EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
> iocInit: All initialization complete
> var streamDebug 1
> epics>
> epics> dbpr DZ:ai
> ASG:                DESC: An analog value                   DISA: 0
> DISP: 0             DISV: 1             NAME: DZ:ai         RVAL: 0
> SEVR: NO_ALARM      STAT: NO_ALARM      SVAL: 0             TPRO: 0
> VAL: 0.003662109375
> epics> Segmentation fault
> :~/testApp/StreamDevice-2-4/streamApp>
> Can anybody give me some hints? thanks a lot for your help.
> Best regards
> Geyang  2008-10-04
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
problem of using Streamdevice Silver
Prev: Re: Process 'bo' on write? David Dudley
Next: October meeting: tarball for IRMIS application layer training Carcassi, Gabriele
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: problem of using Streamdevice Dirk Zimoch
Next: Process 'bo' on write? David Dudley
