1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: problem of using Streamdevice
To: "tech-talk" <[email protected]>
Date: Sat, 4 Oct 2008 19:31:04 +0800
hi, all:
  I am just trying Streamdevice driver by Franksen's suggestion. Seems it's a flexabile way of controlling our equipment. But I met some problems, the ioc will crash quickly after starting.
our streamdevice will response 8 bytes data in hex like "55 40 04 67 39 47 be e3". in the data, "67 39 47 be" is a float's 4 bytes. other bytes are header or crc. So I write my protocol file like this:
# example stream protocol file
#Terminator = CR LF;
ReplyTimeout = 80000; # 10 sec is very long, for keyboard input
ReadTimeout = 1000;   # also long for keyboard input
# note the field access
ai {
    out 170 129 00 129;
    in "%*3c%#R%*1c";
my example.db is like this:
# process this record to reload all stream protocols
record (ai, "$(PREFIX):ai")
    field (DESC, "An analog value")
    field (DTYP, "stream")
    field (INP,  "@example.proto ai terminal")
#    field (PREC, "3")
#    field (LINR, "LINEAR")
#    field (ESLO, "0.000305180437934") # 20.0 / 0xffff
#    field (EOFF, "-10")
#    field (EGU,  "V")
    field (SCAN, ".5 second")
my example.cmd file:
#!./streamApp
dbLoadDatabase "O.Common/streamApp.dbd"
streamApp_registerRecordDeviceDriver
#where can protocols be located?
epicsEnvSet "STREAM_PROTOCOL_PATH", ".:protocols:../protocols/"
#setup the busses
#example telnet style IP port setup
drvAsynIPPortConfigure "terminal", "192.168.1.103:4001"
#asynOctetSetInputEos "terminal",0,"\r\n"
#asynOctetSetOutputEos "terminal",0,"\r\n"
#example VXI11 (GPIB via IP) port setup
#vxi11Configure "GPIB","ins023",1,5.0,"hpib"
#load the records
dbLoadRecords "example.db","PREFIX=DZ"
#dbLoadRecords "scalcout.db","PREFIX=DZ"
#lots! of debug output
#var streamDebug 1
#enable debug output
var streamDebug 1
iocInit
my output of running ioc:
~/testApp/StreamDevice-2-4/streamApp>./example.cmd
#!./streamApp
#setup the busses
#load the records
#var streamDebug 1
iocInit
Starting iocInit
###  EPICS IOC CORE built on Sep 27 2008
###  EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
iocInit: All initialization complete
var streamDebug 1
epics>
epics> dbpr DZ:ai
ASG:                DESC: An analog value                   DISA: 0
DISP: 0             DISV: 1             NAME: DZ:ai         RVAL: 0
SEVR: NO_ALARM      STAT: NO_ALARM      SVAL: 0             TPRO: 0
VAL: 0.003662109375
epics> Segmentation fault
:~/testApp/StreamDevice-2-4/streamApp>
Can anybody give me some hints? thanks a lot for your help.
Best regards
Geyang  2008-10-04
RE: problem of using Streamdevice Mark Rivers
Re: problem of using Streamdevice Dirk Zimoch
Prev: Re: Base R3.14.10-RC1 Released Andrew Johnson
Next: RE: problem of using Streamdevice Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: devStats - OSI version of devVxStats Phillip Sorensen
