1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Base R3.14.10-RC1 Released
To: "J. Lewis Muir" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 3 Oct 2008 15:30:59 -0500
Hi Lewis,
On Friday 03 October 2008 14:25:49 J. Lewis Muir wrote:
> Inspecting /usr/bin/xsubpp shows that it starts with
> #!./miniperl
> I think this must be a bug with the perl installation on RHEL WS 3.
Actually I think it was a bug in Perl that appears to have been fixed by
5.8.4; newer versions seem to insert the prologue automatically when they
install the xsubpp script.
> After this, it built correctly.  I then got your post to core-talk with
> a related change to the Makefile to try to avoid this problem.  I
> reverted my change to /usr/bin/xsubpp and applied that patch and I can
> now build successfully even with a buggy /usr/bin/xsubpp.
Thanks for confirming that fix works.
> I'm getting the following warning messages when compiling src/cap5:
> rm -f ../CA.html
> podchecker ../CA.pm && pod2html --infile=../CA.pm --outfile=../CA.html
> *** WARNING: node
> 'http://www.aps.anl.gov/epics/base/R3-14/9-docs/CAref.html' contains
> non-escaped | or / at line 596 in file ../CA.pm
> *** WARNING: multiple occurrence of link target 'value' at line - in
> file ../CA.pm
> *** WARNING: multiple occurrence of link target 'COUNT' at line - in
> file ../CA.pm
> *** WARNING: multiple occurrence of link target 'TYPE' at line - in file
I suspect that's an issue with the version of podchecker and/or pod2html on
your system, I don't see those warnings here with Perl 5.8.4, 5.8.8 or 5.10.
It may also be that I'm using POD syntax that superseeds 5.8.0; if your
CA.html file is broken you can always use the version that's on the R3.14.10
webpage.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
Base R3.14.10-RC1 Released Andrew Johnson
Re: Base R3.14.10-RC1 Released Andrew Johnson
Re: Base R3.14.10-RC1 Released J. Lewis Muir
Prev: Re: Base R3.14.10-RC1 Released J. Lewis Muir
Next: problem of using Streamdevice Silver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: An error when building EPICS base R3.14.9 on Solaris 8 Evgeniy Tikhomolov
