1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Base R3.14.10-RC1 Released
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 03 Oct 2008 15:25:49 -0400
On 10/3/08 11:17 AM, Andrew Johnson wrote:
> Hi Lewis,
> On Friday 03 October 2008 09:50:55 J. Lewis Muir wrote:
>> On 9/29/08 6:38 PM, Andrew Johnson wrote:
>> Unfortunately, I can't get it to compile on RHEL WS 3.  Here's the build
>> log:
>>   http://www.imca.aps.anl.gov/~jlmuir/epics-3.14.10-rhel3-build.txt
>> The version of GNU Make (3.79.1) is older than the release notes
>> say is required (3.81).  Could that be the problem?
> Yes, you do have to have GNU Make 3.81 (or later) for the build to work now.
> If that version isn't available from your OS packager, it isn't hard to build
> it from source â I had to do that on my home laptop.
Hi, Andrew.
OK, I installed GNU Make 3.81 and that solved the problem.
Then I got a problem building src/cap5 where it failed with
make[3]: Entering directory `/opt/epics-3.14.10/base/src/cap5/O.linux-x86'
rm -f Cap5.c Cap5.c_new
/usr/bin/xsubpp -typemap /usr/lib/perl5/5.8.0/ExtUtils/typemap
../Cap5.xs > Cap5.c_new && mv Cap5.c_new Cap5.c
/bin/sh: /usr/bin/xsubpp: ./miniperl: bad interpreter: No such file or
directory
make[3]: *** [Cap5.c] Error 126
Inspecting /usr/bin/xsubpp shows that it starts with
#!./miniperl
I think this must be a bug with the perl installation on RHEL WS 3.  I
added the following to the top:
#!/usr/bin/perl
    eval 'exec /usr/bin/perl -S $0 ${1+"$@"}'
        if $running_under_some_shell;
After this, it built correctly.  I then got your post to core-talk with
a related change to the Makefile to try to avoid this problem.  I
reverted my change to /usr/bin/xsubpp and applied that patch and I can
now build successfully even with a buggy /usr/bin/xsubpp.
I'm getting the following warning messages when compiling src/cap5:
rm -f ../CA.html
podchecker ../CA.pm && pod2html --infile=../CA.pm --outfile=../CA.html
*** WARNING: node
'http://www.aps.anl.gov/epics/base/R3-14/9-docs/CAref.html' contains
non-escaped | or / at line 596 in file ../CA.pm
*** WARNING: multiple occurrence of link target 'value' at line - in
file ../CA.pm
*** WARNING: multiple occurrence of link target 'COUNT' at line - in
file ../CA.pm
*** WARNING: multiple occurrence of link target 'TYPE' at line - in file
../CA.pm
../CA.pm pod syntax OK.
Installing html ../../../html/./CA.html
rm ../CA.html
Lewis
Re: Base R3.14.10-RC1 Released Andrew Johnson
Re: Base R3.14.10-RC1 Released J. Lewis Muir
Prev: Re: Base R3.14.10-RC1 Released Andrew Johnson
Next: Re: Base R3.14.10-RC1 Released Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
