Shi HaoLi wrote:
> the database record R4IBT04:CISet is like this
> record(ao,"R4IBT04:CISet") {
> field(DESC, "analog output record")
> field(SCAN, "Passive")
> field(OUT, “#C1 S0 @SPT”)
> field(PINI, "NO")
> field(PHAS, "0")
> field(EVNT, "0")
> field(DTYP, "PSC")
Your listing shows the DTYP-line after the OUT-line. If that's exactly,
what your IOC loads, that might be the problem.
Link-fields (so OUT) are parsed depending on the DTYP (still unset when
OUT is set), so the OUT-link might get destroyed when the database is
loaded.
You can confirm this with the dbpr command
Cexp> dbpr("R4IBT04:CISet", 4)
If the OUT-field in the output of this command differs from what is
specified in the db-file, you're done.
Just put the DTYP-line before any of the link-fields (first line after
"record(...) {" is just fine).
Hope it helps,
Thomas
- epics dbpf problem Shi HaoLi
- RE: epics dbpf problem Williams Jr., Ernest L.
- RE: epics dbpf problem Shi HaoLi
Re: EDM xyGraphClass yLabel displaying backwards John Sinclair
<2008>
2025
2026
Re: epics dbpf problem Benjamin Franksen
<2008>
2025
2026
