1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: 答复: How to save the x-y graph?
To: "John Sinclair" <[email protected]>, <[email protected]>
Date: Thu, 16 Oct 2008 22:19:04 +0800
Title: Re: How to save the x-y graph?
Thank you very much. That works.
Now by the default it count once per second. If i want to save the pv value more freqeunce, for example two or four times per second, how can i do?
I tried to use below simple script to save the pv value:
while [ 0 ]; do
caget -a pv >> dat.txt
done
The interval is 2 seconds in the linuxapp, just create a linux application. While for the vxWorks target, the interval is 20 seconds in my case. I did not
find any parameter to set the interval.
Is it reasonable to save the pv value by script? Because in the early folk, the internet condition will have effect on the caget. Some time the socket is lost.
No.239 Zhangheng Road
PuDong District
Shanghai Institute of Applied Physics CAS
Shanghai, China
Tel: +86-21-33933256  Fax: +86-21-33933031
Sent: 2008-10-15 (星期三) 21:32
To: 汪启胜
Subject: Re: How to save the x-y graph?
Right-click on the plot background and choose "dump to file". The file
will be written in /tmp or in the location pointed
to by the environment variable EDMDUMPFILES if it is defined.
John Sinclair
汪启胜 wrote:
> Hi, all
> We use the edm tool x-y graph to record the voltage from ion chamber.
> While i don't know how to save the plot. Does anybody give me some advice?
> Thanks in advance.
> Email:[email protected]
> PuDong District
> Shanghai, China
How to save the x-y graph? 汪启胜
Prev: Re: LvEPICS on USB Key pre-release Mohan Ramanathan
Next: Re: LvEPICS on USB Key pre-release Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: How to save the x-y graph? 汪启胜
Next: epics dbpf problem Shi HaoLi
