1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ioc reading data from files
To: "Pierrick Hanlet" <[email protected]>, [email protected]
Date: Wed, 22 Oct 2008 16:44:49 -0500
We have IOC read data from text files at STAR experiment at Brookhaven
National Lab.  We do something very similar to what Andreas suggested.
In our case, the script it attached to cron to automate the task
instead of making it run every so many seconds.  The down side of
having cron deal with that is that we can only run once every minutes,
but for what we are interested, that's fast enough.
We also pass the input file via sed to make sure the right field goes
to the right PV (our input files contains multiple values that needs
to go multiple PVs).
On Wed, Oct 22, 2008 at 2:43 AM, Luedeke Andreas <[email protected]> wrote:
> Pierrick Hanlet wrote on 21.10.2008 22:00:
>> [...] Until the hardware is all in place, I can use my simple setup to develop my
>> edm panels, etc.  Does anyone have advice, or preferably working examples,
>> of code that reads files from into ioc and the ioc writes the data to the database?
> Hi Pierrick,
> You just want to have your records change in a given sequence to test
> your graphical user interfaces?
> Then don't do it on the IOC, use a shell script instead that reads the
> data from the file and write it with "caput".
> E.g. if you have the file format: <channel> <value> <delay> in your
> file, you could use the shell script:
>    #!/bin/sh
>    while true
>    do
>        read channel val delay
>        if [ $? -ne 0 ]; then break ;fi
>        caput $channel $val
>        if [ $delay -gt 0 ] ;then sleep $delay;fi
>    done
> If you name the script "fileput" and your data file "data" you call it
> "fileput <data".
> Of course you need to have the location of the binary of 'caput' in your
> PATH, it's part of EPICS base.
> Regards
> Andreas
> Dr. Andreas Luedeke, SLS Operations Manager, Tel:+41-56-3104002
> [email protected], http://people.web.psi.ch/luedeke
ioc reading data from files Pierrick Hanlet
Re: ioc reading data from files Luedeke Andreas
Prev: Re: ioc reading data from files Dirk Zimoch
Next: Finding all the PVs on an IOC Carl Schumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ioc reading data from files Luedeke Andreas
Next: Re: ioc reading data from files Dirk Zimoch
