1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Installing Sequencer program
To: "Janet Anderson" <[email protected]>
Cc: [email protected]
Date: Thu, 23 Oct 2008 16:47:12 -0500
Does it not pull in the configuration from the <TOP>/configure
directory?
I have that set already.
David
>>> Janet Anderson <[email protected]> 10/23/2008 3:43:20 PM >>>
The comment in seq/config/CONFIG_SITE about INSTALL_LOCATION_APP is old
and
needs to be changed. Try adding the line
"INSTALL_LOCATION=/usr/local/EPICS"
into seq/configure/CONFIG_SITE.
Janet
David Dudley wrote:
> For some reason, I the sequencer program, it's includes, and
libraries
> insist on installing inside the sequencer local directory.
> I've got the sources installed at /usr/local/EPICSSRC, and trying to
> get everything  installing in /usr/local/EPICS.
> Everything, with this one exception does.  Any ideas of what might
be
> incorrect in this single place?
> David
> BEGIN:VCARD
> VERSION:2.1
> X-GWTYPE:USER
> FN:David Dudley
> TEL;WORK:826-1265
> ORG:;MIS
> TEL;PREF;FAX:880-3741
> EMAIL;WORK;PREF;NGW:[email protected]
> N:Dudley;David
> TITLE:Functional Analyst
> END:VCARD
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:826-1265
ORG:;MIS
N:Dudley;David
END:VCARD
Re: Installing Sequencer program Janet Anderson
Installing Sequencer program David Dudley
Prev: Re: Finding all the PVs on an IOC Tim Mooney
Next: genSub output alignment Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Installing Sequencer program Janet Anderson
Next: Re: Installing Sequencer program Janet Anderson
