1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Installing Sequencer program
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Fri, 24 Oct 2008 09:17:53 -0500
Yes, the <TOP>/configure  files are used.  I meant  seq/configure/CONFIG_SITE not seq/config/CONFIG_SITE.
Setting INSTALL_LOCATION in seq/configure/CONFIG_SITE works for me.
Do you have any $(HOME)/configure/* files or environment variables which may be overriding  settings?
Are you using the latest version of base? Which version of the sequencer are you using?
Janet
David Dudley wrote:
Does it not pull in the configuration from the <TOP>/configure
directory?
I have that set already.
David
Janet Anderson <[email protected]> 10/23/2008 3:43:20 PM >>>
The comment in seq/config/CONFIG_SITE about INSTALL_LOCATION_APP is old
and
needs to be changed. Try adding the line
"INSTALL_LOCATION=/usr/local/EPICS"
into seq/configure/CONFIG_SITE.
Janet
David Dudley wrote:
For some reason, I the sequencer program, it's includes, and
libraries
insist on installing inside the sequencer local directory.
I've got the sources installed at /usr/local/EPICSSRC, and trying to
get everything  installing in /usr/local/EPICS.
Everything, with this one exception does.  Any ideas of what might
be
incorrect in this single place?
David
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:826-1265
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
TITLE:Functional Analyst
END:VCARD
BEGIN:VCARD VERSION:2.1 X-GWTYPE:USER FN:David Dudley TEL;WORK:826-1265 ORG:;MIS TEL;PREF;FAX:880-3741 EMAIL;WORK;PREF;NGW:[email protected] N:Dudley;David TITLE:Functional Analyst END:VCARD
Re: Installing Sequencer program Benjamin Franksen
Installing Sequencer program David Dudley
Re: Installing Sequencer program Janet Anderson
Re: Installing Sequencer program David Dudley
Prev: Re: recordGenerator record Steve Lewis
Next: Re: recordGenerator record Ned Arnold
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Installing Sequencer program David Dudley
Next: Re: Installing Sequencer program Benjamin Franksen
