One way to do this is to use caget(), which can explicitly read a limited amount of data.
This is what I have used for reading image data in my new areaDetector software client.
There are 3 ancillary PVs. xSize, ySize, and frameCounter. When frameCounter increments (new data available) the client does a caget to read (xSize*ySize) pixels.
From: [email protected] on behalf of Liyu, Andrei V
Sent: Wed 10/29/2008 7:54 PM
To: [email protected]
Subject: CA and data acquisition array with variable length in waveform record)
I would like to use EPICS for one system but there is one problem where I can't come to correct solution.
Data acquisition system gets data array. Array length always changes. For example, first measurement has 2000 length array. Next measurement has 50000 length array. Then 2002, 1500, 51000, and so on.
I can create waveform record with 100000 length that will satisfy max points in array. When client subscribes it must set counts of data array. And I, definitely, don't want to transfer 100000 data array each time.
Have anyone solved this?
Thanks, Andrei.
- CA and data acquisition array with variable length in waveform record) Liyu, Andrei V
Generating an IOC with SEQ logic in it. David Dudley
<2008>
2025
2026
<2008>
2025
2026
