1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Generating an IOC with SEQ logic in it.
To: <[email protected]>
Date: Thu, 30 Oct 2008 21:51:21 -0500
OK, oh gurus of the EPICS fantastic....
As I understand things, I need to generate an IOC for my system that
contains the sequencer program I wrote to perform some control on one of
our systems.
I have the sequencer program written, and it operates correctly.
When I generated the sequencer program, I installed it inside the
directory that contains all the other components of the system (in my
case, it's </usr/local/EPICS>, and the sequencer source is in
</usr/local/EPICSSRC/modules/soft/seq/seq> ).
I'm having problems understanding how to create the IOC program with
the sequencer component included.
When I try to generate the IOC, I get the message "don't know how to
generate <filename>.o"
I assume I don't have the right configure files included somewhere.
Any suggestions?
Also, I frequently get a message "... too many open files" when I
attempt to make the system.
Any ideas?
David
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:826-1265
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
TITLE:Functional Analyst
END:VCARD
Re: Generating an IOC with SEQ logic in it. Andrew Johnson
Prev: RE: CA and data acquisition array with variable length in waveform record) Mark Rivers
Next: Re: Generating an IOC with SEQ logic in it. David Maden
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
