1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: how to load several same devices in stream
To: marco_hair <[email protected]>
Date: Fri, 31 Oct 2008 13:06:55 -0500
You have to provide different 'port names' for the devices.  e.g.:
drvAsynIPPortConfigure "terminalA", "10.30.9.28:4016"
drvAsynIPPortConfigure "terminalB", "10.30.9.28:4015"
drvAsynIPPortConfigure "terminalC", "10.30.9.28:4014"
drvAsynIPPortConfigure "terminalD", "10.30.9.28:4013"
I would further suggest that you make the port names something that reflects the equipment attached to the port:
drvAsynIPPortConfigure "Voltmeter", "10.30.9.28:4016"
drvAsynIPPortConfigure "Power Supply 1", "10.30.9.28:4015"
drvAsynIPPortConfigure "Power Supply 2", "10.30.9.28:4014"
drvAsynIPPortConfigure "Current Source", "10.30.9.28:4013"
On Oct 31, 2008, at 12:58 PM, marco_hair wrote:
hi:
I am using streamDevice driver to drive several same devices, they connect to different ports. If I modifiy the example.cmd like this:
drvAsynIPPortConfigure "terminal", "10.30.9.28:4016"
drvAsynIPPortConfigure "terminal", "10.30.9.28:4015"
drvAsynIPPortConfigure "terminal", "10.30.9.28:4014"
drvAsynIPPortConfigure "terminal", "10.30.9.28:4013"
  when ioc runs, it shows:
asynCommon:registerDriver terminal already registered
drvAsynIPPortConfigure: Can't register myself.
If I load only one device, all is ok. Can I load several same devices in one EPICS application? Or need I seperate them to four applications?
Thanks a lot for any help.
Best wishes
Geyang 2008/11/1
网易邮箱10周年,技术见证辉煌
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
how to load several same devices in stream marco_hair
Prev: how to load several same devices in stream marco_hair
Next: RE: GPIB - asyn - streamdevice Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: MVME6100 or 7100 Kate Feng
