Thanks Eric,
I think I can combine these two IOC's into one. Once that is done, do I need to do anything special to coordinate orderly access to the two instruments or does asyn handle it for me?
Thanks again,
Zen
-----Original Message-----
Sent: Friday, October 31, 2008 10:03 AM
To: Szalata, Zenon M.
Cc: EPICS Techtalk
Subject: Re: GPIB - asyn - streamdevice
Would it be possible to run both instruments from the same soft IOC?
I don't think that it would be easy to try and mutex the requests from separate clients of the GPIB/LAN adapter.
On Oct 31, 2008, at 11:05 AM, Szalata, Zenon M. wrote:
> I have two GPIB instruments attached to ICS 8065 Ethernet - GPIB
> Controller (according to the manual this device is a replacement for
> the Agilent E2050 and E5810). I have written two soft IOC's to
> control and monitor two instruments (one is Agilent 33220A Waveform
> Generator, the other is Boonton 4500B RF Peak Power Analyzer). Both
> IOC programs use epics R3-14-9, asyn R4-9, and streamdevice R2-3.
> The 33220A IOC has a records with SCAN="1 second", which reads the
> status byte. The 4500B IOC has a waveform record with SCAN="5
> second", which is used to read waveform data, a stream of ASCII coded
> floating point values. The waveform consists of 500 data points.
> This stream of data is converted to floating point data in a genSub
> record.
> The 4500B IOC program performs flawlessly when it is the only one
> running. When the 33220A IOC program is also running, the waveform
> data read by the 4500B IOC gets corrupted from time to time. I
> interpret what is happening as follows: while the waveform data is
> being read, the other IOC program requests a status byte and somehow
> these two concurrent operations interfere with each other. How can I
> solve this? Is it possible to make reading the waveform an atomic
> operation (i.e. uninterruptable)?
> I am using the following streamdevice protocol for reading the
> waveform:
> rTDCh12{ InTerminator=""; out "TRAC:SOUR CH\$1;:TRAC\$1:INDEX
> 1;:TRAC\$1:AVER:DATA?"; in "%10000c";}
> Any suggestions will be greatly appreciated.
> Zen
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- Re: GPIB - asyn - streamdevice Eric Norum
- GPIB - asyn - streamdevice Szalata, Zenon M.
Re: how to load several same devices in stream Eric Norum
<2008>
2025
2026
<2008>
2025
2026
